So during Covid, early last year, I fell in my shower and shattered the hardened glass panel. I got off with a few scratches, but this is not the post for that.
This is the surviving sliding door section of the shower.
I have the frame of the single panel, in the garage, all intact, sans the silicone insert, where the glass fits into. Getting a new cabin and/or the panel fitted with new glass into the frame was quite expensive, so I am rolling up the sleeves to give it a go myself.
I am in the process of ordering the correct dimensioned hardened glass sheet, with polished edges… actually it may be unpolished as well… pending the price asked for the difference.
Anyway… if and when I get the panel of hardened glass, what advice do you all have for me placing it back in the frame?
I am guessing that I will be needing either silicone, to secure the glass panel into the frame, either via caulking, or by buying a roll of silicone edging of sorts? Apologies if I am not using the correct terminology, by the way.
I have an angle grinder, as well as a rotary tool that I hope with the correct attachment will allow me to at a reasonable pace (somehow though, I feel that it will be a slow and tedious one instead), that will all in all allow me to polish the edges, if I get an unpolished edge sheet. Once the edges have been totally polished, or once I get a polished edge sheet, then I envision that I will need to carefully cushion the sheet into the frame. Thereafter I feel that carefully placing the frame into the slots and caulking the frame where it is attached to both the wall and to the basin, followed up by affixing the door frame to the top of the panel frame with a screw, should do the trick. 24-48 hours later, it should be a fully functional shower cabin once more.
So now, please bring on the advice. All the “to do”s and the “do not”s.
Thanking you all for your time and consideration.
Regards,
Isa
