I have an old lemon tree in my backyard. It used to fruit well until a couple of years ago.
please find attached a photo of the tree for reference.
As mentioned on your other discussion @khoder, we suggest working through our Best Advice article Why is my lemon tree not making fruit? There are a number of possible causes as to why your lemon tree might not be producing fruit.
If you'd like to share more detail on the other discussion about your tree's growing conditions, and share some photos, it would assist our members to provide you with more specific advice.
Thanks,
Hi my lemon tree grows from a seed by it self look very healthy no fruit
Hi @Ngnra
I believe enough of the tree has been trimmed off. We'll just have to wait for this new growth to mature, only time will tell if this lemon tree will bear fruit again.
Thank you for your valuable reply.I have dug into the soil and cut the roots of the parent stock. Have a look and advise if this is ok.Roots cut under the soil —view 1Roots cut under the soil view 2Roots cut under the soil -view 3
Hello again, well those latest photos look great. I’m no expert but I’m a keen gardener. I’m thinking you will need to remove those suckers from under the soil. Right now they’re going to think they’ve had a good prune which will stimulate growth. If you can try remove them from where they’re shooting from the roots. Or at least below the original graft. re fertiliser. I liquid fertilise at the beginning of each seasonal change. If you can do it after a good rain, that’s best. Just remember to water the tree first. Then apply fertiliser. Citrus have a shallow root system and don’t like too much disturbance. You mentioned earlier about pruning back to the ground, I’m hoping you didn’t prune your actual graft completely off. As a rule Citrus don’t require a hard prune, really only need a tidy up. I hardly touch my Citrus when I prune. I’ll remove diseased or dead wood only. Good luck. Hope this helps. Nothing ventured nothing gained or Cuts and consequences. I appreciate and embrace the opportunity to learn. Enjoy your garden.
Can I feed some citrus fertiliser or the liquid fertiliser?
Thanks for the update @Ngnra. Let's hope we see some fruit soon.
Mitchell,
as advised,I have removed the suckers as indicated by red arrows.please find attached the photo.
I agree with @MitchellMc Definitely looks like the rootstock has taken over. I would personally remove it but that’s up to you @Ngnra . Good luck with your lemon tree 😊
Hi @Ngnra,
I am sorry to read your lemon tree has stopped fruiting. You've got a great suggestion from @RobPat to graft a couple of varieties on the existing roots as an option. @MitchellMc will be back online on Friday after a short break so let me tag our experienced garden members @Adam_W and @mich1972 to see if they have any further advice. I'll also tag our other resident DIY expert @EricL who will be online later today to check if he has suggestions as well.
Katie
Mitchell’s explanation was excellent. I’m inclined to agree with him. You could prune those suckers that he’s highlighted in red away, but they’ll want to re shoot. So you’ll need to be tenacious with them. It’d be a shame to start again completely. If there isn’t any of the original graft growing, then why not graft a couple of varieties onto those root stocks.
Thank you for your reply.
I usually use compost annually.
Fruiting details don’t remember, but planted 2012 by gardener.
Have once pruned the tree in 2015 or so right down to the bottom.
what can I do now? Remove the tree and plant a new one?
Please advise.
My first thought when looking at the quite unusual trunk structure is that they are sucker roots from a grafted base that have overgrown your grafted lemon tree. That's an unusual trunk for any lemon tree to have and you'd normally see a singular trunk that branches off above the soil. Here you have many smaller branches coming from the soil. That's a good indication this branch structure is coming from the rootstock, below a graft line, near the soil. Another key detail is the huge thorns on you plant; varieties these days don't have huge gnarly thorns.
Can you tell me if the entire tree bore fruit or if it was more so in the central area? Has any portion of the middle of the tree died off recently? I'm thinking that the fruit you were receiving was from the grafted lemon, and it's subsequently died off, leaving only the rootstock, which typically grows quite vigorously yet doesn't bear fruit or, if it does, in limited quantities. If it does bear fruit, it's generally seed ridden and not palatable. If this is an overgrown grafted lemon, I've indicated below in green what I believe could be your grafted lemon tree in the middle and then in red sucker roots.
This could, of course, be a lemon with an unusual trunk that is just not bearing fruit. When was the last time you fertilised the plant?
