I had some wood rot on my bay window sill, instead of replacing the whole lower section of the timber, I decided to repair the damaged section, the original timber is cedar wood, however, the previous owner repaired the the window sill using hardwood, which deteriorated over time and rotted away, I had a piece of cedar wood, that I shaped to fit the damaged area, I used exterior wood glue, then sanded and shaped the wood to match the rest of the sill.
