Hi All,
Do you all know howi I can be lean the edges of the shower screen? It always came yellow and black even if I change the sealant after awhile it turn yellow/black. Any help greatly appreciate
Hello @calccom21
I suggest using Selleys 750ml Rapid Mould Killer Remover in combination with Sabco Soft Grip Grout Brush. Please make sure to give the mould remover enough time to activate before using the brush. If you use the brush too early the mould remover will not work effectively.
