I have 3 window winders in the bedroom and one window winder is newer than the other 2.
The newer winder opens and closes the window in the opposite direction to the others.
Are there options with new winders or change you change the direction.
Hi @Kvic
Thank you for sharing your question about your window winder. Unfortunately, the majority of window winders in the market are sealed units, which prevents tampering. I believe that the interior mechanism has been designed to go only in one direction. If you can identify the make and model of the older window winders, I can try and track it down for you.
It was just a question but thanks anyway
