This month is Fix It Feb at Bunnings so I’m in the process of making insect screens for my casement windows. I explored a few options eg tracks, access ports (smaller openings to reach windows through), magnetic, lift out etc, but settled on the below with a lower hinged section to access opening and closing. The top two thirds are screwed to the window frame, bottom third is hinged for window access. I couldn't hinge vertically due to pelmets above the window and I didn't want a large hinged area to lift up so I made the top part to suit 910mm fibreglass and bought a 30m roll to eventually do the whole house, probably too much but it was the cheapest option and allows for stuff ups. 😉 Hopefully my post will help others looking to add flyscreens to these old windows and offer DIY options.
Someone in the Bunnings Mums FB group mentioned fire safety as I’ve screwed the frames to the window frame, and I replied that I’ve used 2 short screws either side and the screen is fibreglass not aluminium so where there's a will there's a way in an adrenaline charged emergency, it wouldn't take much to rip them off if needed, bit of a drop below though as the house is a highblock. No kids here either, we're empty nesters.
The large screen has cross bracing to hold it square as my first attempt pulled the top and bottom up like an arc which was obvious when I went to attach the hinged section. The cross brace clips are unfortunately the same size as the 11mm frame that I used so I had to crush them a bit with a pair of pliers to make them fit into the cross frame but once they’re on, the spline fits easily into the track with it in place. Make sure the frame is square before adding the insect screen and spline (also make sure the cross bracing lines up, unlike mine, I didn't notice until it was all together 🙄 ).
I've added weather strip between the sections as I had a bit of a gap between the two frames.
Washing the windows isn’t as easy but I prefer this than cleaning up after the mud wasps have snuck inside and built their nests anywhere and everywhere.
All parts from Bunnings and most from the same bay/same aisle – small mitre box, spline roller, flyscreen trimmer, insect screen (Syneco fibreglass), white frame, 6mm spline, corner stakes, swivel clips, cross brace clips, hinges, white rivets, screws, Syneco weather seal (5m roll under $4). I bought a box of 20 primed hinges then spray painted white to suit the frames.
Extra tools – hacksaw, rubber mallet (needed to persuade some of the corner stakes home), drill, rivet gun, screwdriver, pliers, tape measure, square, marker pen.
