The front of our house needed a new fence as the old one, which was probably built in the Jurassic Period, was looking a little tired and unappealing. After some thought in regard to adding some street appeal to our property, and since we live in a beachside village, we decided on a fence built out of Ironbark in the style of 40 x 40 vertical battens which lends itself the the beachside vibe.
Hello @DIY4Knuckleheds
Thank you very much for sharing such an awesome fence build. I'm in amazement at all the extra details that you've put into the fence, such as the 90-degree bend in the run. The beautiful, rounded profile on each iron bark piece is just fantastic. The counter sunk pilot holes and the decking oil on each screw just shows you that you wanted this to come out perfect. It really draws the eye with its sophisticated look. I'm sure our members will find this design very inspirational.
Again, thank you for sharing such an excellent fencing project.
G'day Eric,
Thanks for the reply mate and l'm glad you liked the fence.
Cheers,
Shane 👍😁🇦🇺
Amazing fence @DIY4Knuckleheds!
You have really transformed your front lawn and given your home some added curb appeal. I like how you have made your process visually easy to follow and it makes me feel like I could do it too. Thank you for sharing this awesome project and I cannot wait to see what you do with the landscaping.
Katie
Appreciate the feedback Katie 👍😁
@DIY4Knuckleheds
Now thats a nice solid looking fence! 🙂 I do like how you have put it together. Is there a reason you put the right angles into it? It makes for a striking feature and would stop it from wobbling (I have a jagged front fence line that I will be doing a similar thing to) It will last for years! 🙂
@Dave-1
G'day Dave....glad you liked it mate 😁 The reason for the right angles is just to add some interest to an otherwise fairly run of the mill front fence. If you go through all the photos you'll notice that where l have set the fence in, l have added in garden beds which further enhances the look of the fence.
Shane 👍🇦🇺
It's a beautiful job @DIY4Knuckleheds, and a wonderful sight among all that colorbond!
Congratulations on a patient & highly skilled result (I hope there are no painful after effects from that cuppa when you were counter-sinking! 🤭😂
Thanks Tyro 👍😁 Those extra tannins from the Ironbark gave a cuppa a little bit of a kick 🤣
Looks great @DIY4Knuckleheds! I’m 1/2 way through building a similar fence. Am interested to understand the jig you used to predrill/countersink the battens - is there anything special you’ve used there?
I plan to place a straight edge between the posts to rest the battens and (fingers crossed) line up the pre-drilled/countersunk holes for my stainless screws.
Any tips you have would be greatly appreciated!
Regards,
Chris
Hello @cbowers
Let me tag @DIY4Knuckleheds as well to make sure they are aware of your kind words and questions. I totally agree that the fence they built is just outstanding. In regards to the jig used, DIY4Knuckleheds really went out of his way to make a perfect jig so that everything lines up. They also used a Macsim 10g Clever Tool Standard Head for that perfect countersink.
My best advice is to make sure that your straight edge is perfectly straight so that everything lines up. But I would still encourage you to use a spirit level just to be sure.
Glad you liked the fence Chris 👍 The jig l used was pretty basic. I just used a strip of 9mm MDF with holes drilled in for the screw holes and a piece attached to the side so that the holes finished up perfectly in the middle of the board. Good luck with it!
Shane 👍
Thanks Shane - perfect! I’ve been using a piece of aluminium right angle with some holes for centres… it’s slow going (thought I must be missing something!). If it turns out anywhere near as nice as yours it’ll be worth the effort.
Thanks again,
Wish l had have thought of using your aluminium angle Chris....that's perfect! Well done 👍😁
