Hey all,
Just installing some IKEA wardrobes and I need to secure it against the wall so it doesn't fall forward.
I've decided to use the Ramset metal hollow wall anchors for the non-stud areas (setting tool looks interesting to use!) https://www.bunnings.com.au/ramset-m6-x-13mm-hollow-wall-anchor-4-pack_p2260147 - in the past I've used the Wallmate ones (for ceiling smoke alarm) but sometimes I make a mistake using an oversized screw woops, and then I can never remove the screw without taking the anchor along with it, so these metal ones look more suitable.
Anyway, can I use alternate screws to fit into these anchors? Or are they only suited to use the ones that come in the pack?
Ultimately I'm using a piece of wood behind the wardrobe to secure properly against the wall (I have skirting so it doesn't sit flush). And the screw that comes with the pack doesn't look like it would sit flush. Also I don't like Phillips slot screws, I have a habit of slipping haha. So I'm interested in using star headed screws (like https://www.bunnings.com.au/buildex-10-10-x-50mm-white-star-head-cabinet-screw-50-pack_p2400122). I'm guessing so long as the width (gauge?) matches, it should be fine but just want to be sure.
Cheers!
