Hi!
I’d like to get some advice on this project I’ve been planning in my backyard below.
I'm looking to install James hardie cladding sheets in front of the existing timber fence, left and right side of the above image. I don’t want to mount the cladding on to the existing fence as it won’t take the weight, I will need to build a new structure in front using metal posts with baseplates dynabolted to the concrete and timber battens running top, middle and bottom to fix the cladding onto. I’ve attached an image I’ve found on Facebook and also the posts I found to use.
Questions.
Will the metal post dynabolted to the ground and timber battens running across be able to hold up the weight of these boards 26kgs each?
13m distance, 2.4m high.
How do I level the baseplates as the concrete slopes toward the drain?
Has anyone completed a job like this and have photos? Or if anyone has advice on best practice for this project.
Thankyou!
Griffin
