Hi.. does anyone know how to remove the case on the fan light cover? I tried to twist to open but now it cracked. Anyone know if Bunnings sells a replacement cover?
The cover is a clip on and is 14cm in diameter. I accidentally twist it
Hi @calccom21,
Ceiling fan light covers are typically designed to suit that specific fan and light. We could order a replacement cover for our units, but it's not likely to fit your fan. If your fan is one of our units, could you please let me know which one? I'd gladly contact the manufacturer to check on the availability of spare parts.
Hi @MitchellMc yes bought from Bunnings. I do not have the model number but attached the photo is the model I bought back then from bunnings
There are replacement covers available from Arlec. The part number is SS2537, and it can be ordered through your nearest store's Special Orders desk.
To remove the cover it requires you to pull the cover straight off. There are internal spring clips that hold it on. It is not a twist lock fitting. Since the glass is already cracked, please wear cut-resistant gloves, safety glasses, a long-sleeved shirt and trousers and enclosed footwear when removing it.
Thanks @MitchellMc any idea how much is it?
Hi @calccom21
I'll give Arlec a call tomorrow and find out how much the cover will cost. As soon as I have the information, I'll let you know.
Thank you for your patience.
The replacement cover is currently priced at $17.85 including gst. I suggest speaking to your local stores special orders desk and asking for quote on the SS2537.
If you need further assistance in ordering the cover, please let me know.
Awesome thanks Eric for your help...
