Difficulty: Beginner
Cornices conceal the joint between a ceiling and a wall and add a decorative element.
It’s common for cornice mouldings to crack or get damaged over time. This can be unsightly and potentially dangerous.
Here is a simple guide to repairing a cracked cornice using a multi-purpose sealant.
As this project involves chemicals and power tools, please follow all safety guidelines provided by manufacturers and use the recommended safety gear.
Let us know if you have any questions. We’d be happy to assist.
Steps
Step 1
Open the gap.
Use a scraper to open the gap or crack between the cornice and wall so that you create space for sealant. Without a gap, the sealant would only be applied to the surface and any new movement would split the cornice again.
Scrape off the paint at any points along the crack where the cornice is still attached to the wall and remove any loose debris.
Do this until you can fully insert the scraper behind the cornice.
Step 2
Remove any remaining debris behind the cornice.
Insert wedges in the crack by tapping them in place with a hammer.
Place a wedge every 300mm along the crack to keep it open. Be careful not to drive in the wedges too far as this could cause the cornice to crack further.
Now use your scraper to remove any remaining debris caught behind the cornice.
Step 3
Glue the cornice to the wall.
Insert your sealant cartridge into the caulking gun. Place the nozzle behind the cornice and fill along the length of the crack.
Now remove the wedges. Use a rag to remove any excess sealant that may have leaked from the crack.
Step 4
Screw the cornice to the wall.
Use a drill driver to pre-drill countersunk holes every 15cm along the bottom edge of the cornice. Make sure you are wearing personal protective equipment (PPE), including gloves and safety glasses.
Avoid placing holes too close to the edge. This can cause the cornice to crack.
Now insert screws in the holes and drive them into the wall.
Step 5
Seal the crack.
Tape the area above and below the crack. Use the caulking gun to apply sealant along the crack in between the tape lines.
Now wet your finger in soapy water and use it to smoothen the sealant.
Remove the tape about two minutes after applying the sealant. Do not allow the sealant to dry before removing the tape or you might remove the sealant with the tape.
Step 6
Fill the screw holes.
Use your caulking gun to fill the screw holes with sealant.
Smoothen the sealant with a wet finger, as in the previous step.
Allow the sealant to dry for at least an hour.
Step 7
Paint the cornice.
Paint over the repaired area for a smooth finish. This will also help ensure the repaired area blends seamlessly with the rest of the cornice.
You have now repaired your cracked cornice.
