Steps
Step 1
Remove the fly screen.
Unscrew any clips or fasteners holding the screen in place. Hold the screen’s left and right edges and push it upwards into the window frame’s top track. Do this until the screen's bottom edge slides out of the bottom track. Now remove the screen out of the frame by pulling it down out of the top track.
Locate a clean and dry area for cleaning the screen and place it there.
For fixed fly screens, place towels along your windowsill and floor to protect them from any water or product stains.
Step 2
Dilute the degreaser.
Follow the instructions on the product label to dilute the degreaser. Make sure you are wearing the recommended personal protective equipment (PPE), including gloves and eye protection.
Fill the bucket with the required amount of water and add the degreaser. I added one part degreaser to 10 parts water.
For heavily stained or dirty screens, use the degreaser undiluted.
Step 3
Scrub the fly screen.
Dip a soft bristle brush into the diluted degreaser and then use it to scrub the screen. Do not scrub the screen too vigorously as doing so can damage the mesh.
Scrub both sides of the screen.
Step 4
Wash the fly screen.
Lean the screen against a wall or post. Hose off the dirt and degreaser solution until the water runs clear. If the screen is still dirty, repeat step 3.
For fixed screens, use a spray bottle filled with water and a wet cloth to wipe away the dirt and degreaser solution.
Step 5
Dry the fly screen.
Leave the screen to dry outdoors in a clean area.
For quicker drying, wipe the screen gently using a clean towel.
Step 6
Reinstall the fly screen.
Once the screen has dried, push the top edge of the screen up into the top window track. Now insert the screen's bottom edge back into the bottom track. Position the screen in the frame and clip the edges back into place.
Enjoy your clean fly screen.
