we have tried lots of different vacuum cleaners in the past and using it and cleaning the vacuum cleaner is a big mess. Which best vacuum cleaners are practically good and less or easy Maintenace
Hello @nddi
Welcome to the Bunnings Workshop community. It's wonderful to have you join us, and thank you for sharing your question about vacuum cleaners.
Choosing the right vacuum cleaner can make a significant difference in your cleaning routine, and it's important to consider several factors when making a decision. Firstly, it's essential to choose the right type of vacuum cleaner based on your cleaning needs and preferences. Upright, canister, stick and robotic are some of the most common types of vacuum cleaners available at the store.
Next, consider the type of flooring in your home. Different vacuum cleaners work better on different floor types. For example, a vacuum cleaner with a brush roll is perfect for carpets, while a hard floor tool is best for tile and hardwood floors.
A good example is the VAX SlimVac Pro Pet Cordless Vacuum. It's multi surface floor head is designed to go over different types of floors. It's easy to empty out and has many useful attachments.
Having a combination of vacuum systems will ease the burden on a single stand-alone system. A stick vac will let you clean sections of the house or a single room. A robotic vacuum cleaner like the Arlec Grid Connect Smart Robotic Vacuum is like an assistant that picks up the dust even when you're not home. Then you have your main vacuum cleaner that is manoeuvrable and easy to empty out.
One example is the Black & Decker 1800W Barrell Vacuum. It's bagless with an independent dirt canister that lets you empty it out with a push of a button.
Finally, determine your budget and choose a vacuum cleaner that fits within it. Vacuum cleaners come in a wide range of prices, so it's essential to find one that meets your needs and fits your budget. By considering these factors, you can choose a vacuum cleaner that's best suited for your home and cleaning needs.
