In repairing gutter downpipes, how can I separate a PVC fitting from the pipe?
How do you mean? where the PVC joins the gutter? or where it joins the sewage pipes?
If you mean where it joins the sewage pipes if it has been glued you won't be able to get it out of the T join or whatever it might be. You may have to cut the pipe higher so you can attach a joint to connect the new pipe to the old pipe.
https://www.bunnings.com.au/holman-90mm-pvc-stormwater-slip-coupling_p4750197 something like this?
Welcome to the Bunnings Workshop community @BrowningB. It's tremendous to have you join us, and many thanks for your question about removing fittings from PVC pipe.
It's great to see that @MrSober is already on the case and has provided a helpful answer. I agree, as typically, PVC fittings are attached to the pipe with solvent cement. This effectively melts the plastics together and is not a connection you can undo. If the pipe has only been pushed onto the gutter dropper outlet, you'll likely be able to pull the connection apart.
As they've mentioned, you would cut the pipe prior to the connection leaving around 50mm of it. That will give you enough pipe to connect your new coupling and pipe.
Hi @MitchellMc,
There is another way around this, but it isn't for the faint-hearted, this has got me and a few plumbers out of trouble a number of times and as long as you're CAREFUL and don't try and do this in 5 seconds flat, it can work quite well.
Here we go:
Once the piece of pipe is removed, use some emery tape or abrasive paper to scuff up the internal surface of the fitting before reusing this to give the glue something to "key" to, when you glue the new piece of pipe in there.
This may sound pretty rough, but it actually does work as long as you watch what you're doing.
I hope this helps someone.
Cheers,
Mike T.
The PVC pipe in question is a gutter down pipe shown in the picture. the problem is that it is painted and I am reluctant to cut it as I do not think it will fit into a fitting. Also I now find the long down section is pushed in at the back and I need to replace it which means purchasing 3 m of pipe. What is best- Replace the lot?
Hello @BrowningB
If you're trying to remove the entire downpipe, I've placed yellow circles on what you need to unscrew to allow you to remove the entire assembly off your house.
If you are replacing the entire downpipe set with 90mm pipe, the basic parts are as follows:
