Steps
Step 1
Remove old varnish. This takes time and patience. You need to strip the timber back to bear
Step 2
Add an undercoat to the frame, then paint the frame white. For the side pannels, only undercoat, no need to top coat
Step 3
Measure and cut superfresco breadboard paintable wallpaper so that it fits into the side panel frame. Fit wallpaper into the frame with wallpaper glue
Step 4
Paint the wallpaper white and add silicon sealing around the wallpaper in order to insure no lifting
Step 5
For the table top and draw fronts, rub a small amount of feast Watson
lime wash with a rag until you get your desired whitewashed look
Step 6
Add timber handles, which I also used the lime white wash to match the draw fronts and table top
