[I tried to find this forum which has helped me previously but I couldn't locate it and Bunnings said it doesn't exist anymore]
I decided to build a computer cabinet using Bunnings laminated MDF shelves. I tried to get advice on the best way to go about it, but without any real success. So I set about building it by drilling holes through the end panels and putting chipboard screws through the holes into the edges of the top, middle shelf and bottom panels. It was quite rickety so I installed some angle brackets in it and altered the screws from 8 gauge 30 mm to 10 gauge by 50 mm. It's better and ok for what I want to use it for. In putting the longer screws in, I found some of the pilot holes I drilled into the edges of the horizontal panels are not parallel to the surfaces of those panels, so some of the new long screws have cracked the surface of the horizontal panels. My two questions are:
1. Was there a better way fro me to have gone about the construction; and
2. Is there a tool which would enable me to drill holes that are exactly at right-angles to the surface I'm drilling through?
Thanks
