Steps
Step 1
- Quick sketch design and check in with Bunnings Workshop community to seek advice!
- Clear and level ground around tree for base
- Lay and compact 20mm gravel for base of frame to sit on (to help provide a sturdy base and improve drainage)
- Paint all wood in contact with ground with Bondall wood protector
- Cut and fix timber with large screws
Step 2
- Cut and attach frame legs using M12 through bolts
- Cut notches in top of posts for frame sides, ensuring all plumb and level
- Install frame sides using M12 through bolts
Step 3
- Install joist hangers for joists using structural nails
- Install joists made from treated pine - size and spacing of joists based on expected deck weight and length of joist span
Step 4
- Install spotted gum decking on top of floor joists
- Install balustrade frame using cut lengths of spotted gum decking before installing branches collected from site as railings
- Treated pine used to create cubby frame with fence palings used for cladding - all fixed with treated pine screws
Step 5
- Final fit out including wooden ladder with climbing holds
- Rope ladder
- Trap door made from wood scraps and gas lift struts
- Install periscope, wheel and bell
- Add pirate swag (flag, spray paint decals)
- Encourage kids to stop watching TV and get outside!
