I purchased the fibreglass pond several years ago from Bunnings and I since had a change of plan so it was not until recently I put it all together.
Owing to the Queensland climate when there is often torrential rain I decided to set the pond on a pedestal in this case on an old terracotta pot. In order to shelter it from heavy rain it has been partially covered under the eaves.
I had a Buddha head with its own plate underneath which had been used with a candle hence the holes in the head.
The pond has a shelf built in for plants as well and I purchased Goldfish for the pond and to give it a special feature I bought Solar Fireworks fairy lights online to give it some pizazz at night
Steps
Step 1
When choosing the pedestal size try to get a proportionate pot to suit the pond so that it looks balanced top to bottom and make sure the base of the bond and the pedestal" sit well" together.
Step 2
Choose an area to place you pond so that it can be easily accessed all around to attend to cleaning.
Step 3
When assembling the two parts together be sure to test pond for any leakages by filling with some water first.
Step 4
Next place base (Pedestal) and place spirit on top to check its level and then with someone else place pond onto pedestal
check levels again very important. If they are out ever so slightly you can use coins ie.. 20c pieces to balance the levels.
