Hi, my shower screen door has water leak and as you can see the pic, there were water spots on the tile outside. How do I resolve them? I would definitely sure that the water came from the shower inside.
Hi @gavin16
Thanks for sharing your question about cleaning the watermarks off your tiles. I suggest testing out CLR 750ml Bathroom And Kitchen Cleaner in combination with a Scotch-Brite 155 x 100mm Heavy Duty Scourer Pad. Just make sure to give the CLR enough time to activate before you start scrubbing the tile.
In regards to your shower leak, I suggest using Selleys 100g Clear Ezi Press Wet Area Silicone Sealant for small to medium repairs.
Here is a handy step-by-step guide: How to silicone seal a bath (the techniques used are applicable to the inside/outside of your shower panel)
Please make sure to wear personal protection such as gloves and goggles when using the cleaning agent.
