Steps
Step 1
First I removed the existing hardware and gave the dresser a thorough clean using sugar soap.
Then I removed the varnish from the top using my carbide scraper, before sanding with a Ryobi orbital sander.
Step 2
After wiping clean, I primed the dresser using Taubmans 3 in 1 prep and painted using Dulux interior, in the colours Colorbond Dune and Natural White.
Step 3
For the top drawer, I used jumbo popsticks to create a herringbone pattern, which I glued with Gorilla wood glue.
Once dry, I used my Ryobi multi tool to cut the over-hanging popsticks, before sanding the top and edges smooth. I filled all gaps and edges with wood filler, sanding again once dry. I drilled new holes for the handles.
Step 4
I sealed all natural timber surfaces with Feast Watson liming white and the painted surfaces with Cabot's water-based polyurethane.
Step 5
I used peel and stick wallpaper to line the drawers and finished off the dresser with new brass knobs!
