Steps
Step 1
Remove the old shower head.
Place an adjustable wrench towards the end of your shower arm near the wall. The shower arm connects the water outlet on the wall to the shower head. Adjust the wrench to fit the shower arm and turn anti-clockwise.
Once the shower head is loose, turn it by hand until it comes off. The water outlet on the wall should now be visible. This is also known as the brass nipple.
Step 2
Replace the thread seal tape on the brass nipple.
Remove all the old thread seal tape on the brass nipple by hand.
Some brass nipples may also allow you to remove the back flange, which is a silver ring attached to the brass nipple. However, do not remove the back flange if it is stuck with silicone.
Now wrap the new seal tape around the brass nipple in a clockwise direction. Rotate the tape around the brass nipple at least four to six times.
Step 3
Install the new wall mount holder.
Purchase a new shower head set. These typically come with a shower head, a wall mount holder, and a shower hose.
Line up the wall mount holder so that its base is parallel to the brass nipple. Turn the base clockwise to attach it to the brass nipple.
Make sure that the holder’s exit hole points down to the floor. If it doesn't, turn the holder anti-clockwise until it points in the right direction.
Step 4
Connect the shower hose to the shower head and wall mount holder.
Connect one end of the hose to the shower head and the other end to the wall mount holder. The cone-shaped end of the hose goes into the shower head and the nut-shaped end goes into the wall mount holder.
Use your hands to tighten the hose while attaching it to the shower head. You can use an adjustable wrench to firmly attach the hose to the wall mount holder.
Once the hose is connected to both ends and the shower set is installed, test it to ensure there are no leaks. Turn on your shower. Water should only be flowing from the shower head.
If there are any leaks, tighten your hose fittings again. You may also need to reapply your thread seal tape around the brass nipple.
You have now successfully replaced your shower head.
