I would just like to clarify a few things regarding installing my bluestone pavers before I begin.
The first problem I have is do I need to seal the pavers for outdoor use? I intend to use bondcrete (or a more compatible product for natural stone) on the underside and in the mortar mix for maximum adhesion, but I've read that a "picture framing" effect can occur due to moisture being sucked up from the underside of the paver and staining the edges of the top surface, also a white powdering can occur due to minerals being drawn up on to the surface which I would like to avoid
the second problem I have is if I am sealing all 6 sides, will a PVA ptoduct like bondcrete still adhere to the paver? or will it be compromised?
could I please be directed to the most appropriate products and the most compatible for the best result! I want to have long lasting and well looked after pavers!
thanks in advance!
