Hello ,
Im assuming the Estilo 900mm x 900mm 4 Lip Centre Rear Outlet Shower Base will fit with the Estilo 900 x 1830mm White Semi Frameless Shower Screen. Or, do I need the 3 lip model ?
For fitting of screen does it depend on how far into wall base is fitted ? ( checked into wall framework to allow finished tile to sit over the lip.?} .
ie. Do the 2 walls of shower screen have lateral adjustment ?
Thank You
Welcome to the Bunnings Workshop community @Pete50. It's great to have you join us, and many thanks for your question about shower screens.
You're correct that those products are compatible with each other.
You'll notice that the base has a raised section on it. The screen can be placed anywhere between the two arrows and moved around to suit how far the base is rebated into the wall. The raised section is quite wide, so you have plenty of available movement.
Gday!
I am just about to fit this shower to the required pan.
I noticed in the wall channels there are 4 predrilled holes for grub screws (not for the wall) I didn’t get these or have lost them. Can I use anything else from bunnos, and which ones.
also, I noticed at the joining pieces about 80mm from the corner join, there is also 1x predrilled hole in each. Is there meant to be a bracket to join the two screens together? I may have also lost that.
can I purchase these items and can you let me know so I can get the correct ones please
Hello @Lockyd
Would it be possible for you to post a photo of the wall channel and the joining pieces you are referring to? We just need to be sure that we are thinking about the same parts so that there will be no confusion. Once we see the photos, we should be able to identify the parts you are talking about.
Thanks,
Howdy, I actually JUST came across the missing pieces and the instructions haha!
That is good to hear! I'm glad you found the missing parts.
If you need assistance with anything else, please let us know.
