Situation: 10kw of solar is being installed on my roof Williamstown Victoria. I have separate gas heating and gas hot water systems. The latter is showing end of life symptoms i.e. brown hot water.
The 10 kW will far exceed our electricity requirements until i load it up with heavier electrical appliances in a time-of-day intelligent manner.
Questions:
What's the best solution (price/subsidy output for variable solar input, output for variable environmental conditions), for hot water in my case? Assume 4 bedroom 2 storey home.
When the sun doesn't shine and it's cold can i still have hot water?
Do heat pump hot water systems boost with regular resistive heating in cold conditions?
Are heat pump HW heaters better than regular resistive heaters for price and return on investment?
Do heat pump hot water systems also heat or cold the home?
Is noise an issue with best pump systems?
