Hi DIY Mind Hive. There seems to be two schools of thought around replacing painters tape between coats so I'd like an expert opinion. Some sites indicate that if you are doing multiple coats of paint then to leave the painters tape until the second coat (assuming you are doing two coats) is touch dry. Other sites indicate the tape should be removed after the first coat is touch dry and replaced for the second coat. Thoughts? Experiences? Thanks.
