Steps
Step 1
The project was on hold as I had run out of enough mesh for the cage. I was lucky enough to reclaim a sheet from work and we used the guillotine to cut it instead of cutting disks for a grinder. Making sure I had it located right before filling was a fidly thing as the pathway and compacted clay was higher then the footing level of the basket.
I had some small leftover pieces of mesh so decided on two baskets, a shorter length one and a longer one.
I have shown how the spirals are made in other projects, see (Gabion Wall to stop water ingress to garage )
The cage went together pretty easily, note - make the spirals around 40cm - 50cm long for ease of installing them.
You can see the shorter spirals I use, it makes it easy to wind small sections on.
The white temorary blocks will be removed and the clay at the base leveled.
Sorting out what type of angle I wanted.
Dry fitted to the places I wanted the cages to go.
Showing the height difference in the ground (Yes thats a paver standing on end to support the cage!). More clay to compact... Fun.
Step 2
Time to level the ground and compact it before I could fill the cages.
I had to tamp the clay so as to create a firm base for the cage to settle into when full.
You can see the height of the path verse the baseline of the wall. I wasnt worried about it collapsing as it was all clay that had been packed solid.
Always make sure the cage is level in both perspectives.
Happy 🙂
After I had back filled a LOT. I hadnt realised how much the path sloped until I had to level up the cage.
Bound for reuse one day 🙂
All this will be used/shifted as I work my waythrough the job. I really dislike double handling anything.
Cages in place. Time to fill.
Taking out the steps and path, what do you find under the 10mm of concrete but more pavers!
Step 3
I made sure I faced the viewable wall with nice looking concrete (to go with the same style of the large cage next to the garage) I used all the grey and broken bricks on the inside where you cannot see them.
I didnt have any stay wire when I was filling them, I had forgotten to buy some. So I used some off cuts of mesh instead. I did put stay wires in afterwards tho. (They are used to stop the cages stomach from spreading)
You can see an offcut being used in the middle to stop the walls bowing.
The waste pile is getting smaller
People may see mess, I see resources! Lots of resources!
It always helps me visualize the job if I sketch it out.
This was the first option but decided it was too much effort to backfill with soil.
Pretty much how it turned out.
Spot the patio issue... Noted to be done at a later date.
I used ratchet straps to bring the lid and wall together so I could then spiral them together. The ratches work a dream.
The cage is full and spiraled together. I use the long nose pliers to grab and rotate the spiral so it twists on. The gloves are essential as your hands will get ripped to shreds from the stones and wire.
The cage comes together so nicely and on a scale of 1 to 10 about a 3 in effort.
You may think what has he done? Thats a huge gap to fix up. The Ratchet placed every foot and a half (I only had two) then synced up and using a mallet to tap the stones through the cage. Dont hit hard otherwise you can bend the mesh. Its a gradual process but easy to do. Once the cage is spiraled move down the length and repeat.
I generally put the long hook of the ratchet over the top of the cage onto the back wall making sure the strap dosnt go through anything sharp and the short hook half way down the front. Then slowly ratchet it up. This seems to work the best.
Spiraled! Eventually I will install timber over the top to create a bench style seating.
Will backfill and widen the pathway.
Step 4
Now that the cages are in place its time to fill behind them. I used the last of my upholstery cloth that was going to be thrown out (You could use geotec cloth instead) to stop fines from entering the basket.
This material has come in so handy for stopping fines moving through into the cage.
All ready to go
Floor edging that is being repurposed, I am using it to be the final edge against the rear of the gabion basket to stop gravel from pushing into the geotec material and then into the basket.
Edging in place
Cleaning up, the daisy bush is to be moved tho not sure it will survive the move.
Moved! and raked
Top down look.
Step 5
Last step was sowing some grass seed. I am still unsure of it being grassed/bark chipped or something else (Not pebbles!) I figure we live in a drought prone country so I should be hedging my bets plus I dislike mowing!
I used some of my pile of topsoil for the last couple of inches of the area.
Plus brought some golf grass seed, I love the feel underfoot but its going to be pretty much a temp thing I figure.
Within 10 days!
I put down a second box's worth at day 10.
Seriously nice lush green grass 🙂 after 20 ish days!
Really makes a statement but the first week of summer and it was to be no more 😕 lol I could lay down turf but then I would have to mow it....
Very happy with how this stage worked out. The water dosnt pool, nothing gets muddy to the point of sinking. Only issue is what do I use here to cover the area especially if I put in a firepit.
