We’re planning to build a low level deck over our exposed aggregate courtyard using aluminium framing and Ecodeck slats and wanted to know whether we should clean and re-seal the concrete before we build the deck over the top?
I know sealing it will only last for a few years, but thought it might be worth doing to help delay any deterioration in the concrete due to moisture/moss etc. We were planning to re-seal the parts of the concrete that won’t be covered by the deck anyway, but didn't want to do the concrete where the deck will sit if it wasn't necessary.
Some more context:
- I don’t believe the concrete has been re-sealed since it was originally poured 12+ years ago
- The courtyard has reasonable drainage (see photo below)
- To the left of the rainwater tank man hole is fairly flat
- To the right it slopes away to the garden bed/drain.
- The courtyard isn’t covered
If the consensus is to go ahead with re-sealing, would a penetrative sealer be the best option and should we acid etch the concrete before applying the sealer?
