Hi Team, I'm looking for suggestions for a weed killer that can effectively eliminate weeds in our nature strip without harming the lawn.
Hello @RK07
I suggest using a combination of manual removal and Yates 2.4L BuffaloPro Weed 'n' Feed Hose On Weed Killer. Removing the large weeds by hand will provide more space for the lawn to grow back in. The Weed n Feed will then do its job and you'll just need to remove weeds once they turn brown.
Please dispose of the weeds in the bin and do not add it to your compost. Please makes sure to wear personal protection such as gloves, goggles and an appropriate mask when using the spray.
Here is a link to our best advice: How do you control weeds in your garden?
Hi @RK07,
I would also recommend investing in an old-school hand weeder for removing weeds like dandelion. If you do a little at a time it can almost be therapeutic!
Hi Eric, Yates 2.4L BuffaloPro Weed 'n' Feed Hose On Weed Killer mentions that it's specially for Buffalo grass. I think my nature strip grass is Kikuyu grass. Will it work on that?
Thank you,@Jason, I have just purchased it and will give it a try this weekend 🙂
If you have Kikuyu grass, I suggest using the Yates 4L Weed 'n' Feed Hose On Lawn Weed Killer. This version is made for Kikuyu grass.
Just stumbled along your advise request @RK07 and wondered how you got on, I know it's been some time since you made your request but wondered what your result was and how long it took you?
I have found myself in a similar situation and truly have no idea where to start or which lawn to go with. As there are two possibly 2-3 lawn types I can identify.
Thank you
Old gal
Hi @Old-gal24,
Just to clarify the choices in weed killer that my colleague @EricL has mentioned, if you are unsure of the lawn type that you have, Yates 2.4L BuffaloPro Weed 'N' Feed Hose On Weed Killer is effective for all lawn types including Buffalo, Yates 4L Weed 'n' Feed Hose On Lawn Weed Killer is not suitable for use on Buffalo lawns.
If you are unsure of what type of lawn you have, it is best to use a weed killer that is safe for use on Buffalo lawns.
Let me know if you would like further clarification.
@JacobZ
Thank you for your reply. If there is Buffalo there, it's a small amount. The largest amount is Kikuyu and Couch, if that's a lawn? The bulk looks like it may have started as Couch/Bermuda, with a mix of Kikuyu and a mix of weeds, some I haven't seen before. The worst with be getting rid of the large patch of nut grass. Now that stuff is nasty to try and be rid of.
Sadly much of the staff at our local Bunnings store don't know much about gardening let alone weeds. So thought I would ask in here as there are so many others with lived experiences with weeds and lawns.
Thank you for your replies @JacobZ @Jason @MitchellM @EricL @Jason
Hello. Well. Years and years ago, I gave up digging up weeds etc. in the nature strip. And several times, I poisoned the whole stretch - 30 meters. Looked like the Gobi desert. I didn't care one bit. I did this several times at different times of the year. And so guess what....the whole lawn came back, initially without weeds, but not for long. So what I've decided it's absolutely not worth, at all, worrying about weeds etc., in your lawn. The nature strip gets mowed, weeds and all, and it looks so lovely and green. So absolutely not worth, at all, worrying about - just mow it. Supposedly if you feed the lawn, that will make the lawn stronger, and choke out the weeds. No. Never happened. So my advice - is just live with the weeds in the lawn. Mow it, and it will look fine. Believe me. And then.....you can rest easy, and not stress about something that is sooooo not relevant. Bless you.
There has to be a better solution, other that killer poisons. Far too many are keen to use poisons....but what else are they killing.....just to have a perfect lawn???? Good grief. A lawn is a patch of greenery. Gardeners have to stop poisoning everything and anything.
