Hello! I have had some 50mm diameter round steel posts (Standard posts, I assume 3-5mm thick) concreted into the ground as netting posts around a new basketball court. They first need cutting to size before I install the netting hardware (Why the person didn't cut them to size before concreting them in I'm not sure). They are very tall and I will need to be close to the top of a high ladder to cut them i.e. it's a bit tricky and I may have to be working overhead in one or two cases.
My question is: what is the best way to cut them to size given the awkward nature of the site? I have an oscillating multi-tool which, given the various angles you can hold it at, I assume would be ideal but would that be okay for the job? I've only used it for wood so far. Happy to buy a larger/more appropriate blade for the job. I first assumed I'd need to buy an angle grinder, and still can if needs be but if the multi-tool will work that would be excellent to save money.
Many thanks!
Mike
