Fitting a transition cover trim between rooms and adding scotia moulding to the walls.
The project
I recently did my first attempt at laying hybrid flooring (replaced the existing carpets) on the concrete floor in my small living room.
I planned on adding scotia moulding, but before I did that, I wanted to get the transition between the tiles and the hybrid floor sorted. The gap of the transition is about 10mm and the edge of the tiles appear to be 3mm higher than the hybrid flooring.
Firstly I went out and picked up the QEP Cover Trim. I was a bit worried at first it would make movement as you walked over it, but after a day of it being held down with the Construction Adhesive, it's 100% not moving and it feels safe to walk over.
I also purchased some Scotia Moulding.
Using a Compound Mitre Saw, I cut the scotia moulding to the correct length and then attached it to the skirting board using a Ryobi 18V ONE+ Brad Nailer. I then primed the scotia moulding with Dulux 1L PRECISION Maximum Strength Adhesion Primer White, and once dry, painted over it with the Dulux colour White on White, so it matched the skirtings colour.
For the finishing touch, I filled the gap between the scotia moulding and the skirting boards with Selleys 475g No More Gaps Interior Multipurpose Gap Filler. I'd say overall it was a success.
[article footer]
More inspiration for your flooring project
Community member RAW has shared a list of tools and materials they used when they completed their D.I.Y. hybrid flooring installation.
Workshop member WoodenGregsWood has shared the steps he took when he did his hybrid flooring installation.
Get more ideas for your home from our article 5 ways to revamp your floors.
We're here to help if you need advice or assistance with your own project. Feel free to ask a question and our helpful community members will be happy to assist.
[article footer]
