I removed my sink tap's aerator and put on this BSP thread aerator adapter: https://www.bunnings.com.au/kinetic-adaptor-aerator-kit_p4920386
Now I cannot unscrew it. I had screwed it on manually by hand, but it does not unscrew now. Any ideas?
Thanks
Hello @NinaSD
That's great news, I suggest brining the old aerator to the store so that you can compare it to the replacement sets available. Please make sure to give the spout threads a good wipe down before you screw the new aerator on.
It worked with a multigrip plier. Thanks very much @EricL and @MitchellMc 🙂
Thank you for the update. I'm afraid the long nose pliers does not provide an ideal angle to grip the aerator. I suggest going with @MitchellMc's suggestion and using multigrip pliers. These pliers are adjustable and able to grip non-standard items such as aerators and unusual plastic or metal fittings.
If you wish to protect the aerator, I suggest covering it with a soft cotton shirt and then gripping it with the multigrip pliers. Please remember to turn it anti-clockwise to loosen it up and clockwise to tighten it. If you are still having problems with grip, I suggest wrapping the aerator with rubber bands so that the multigrip will not slip.
Thanks Mitchell!
I have difficulty removing the 15mm BSP thread aerator adaptor (male to male). I have tried using a long-nose plier, but no luck. The plier moves, but the adapter doesn't rotate either way.
There was a similar post back in 2020, but I'm not sure how that was fixed: https://www.workshop.bunnings.com.au/t5/Whole-of-House/How-do-I-unscrew-a-stubborn-tap-adaptor-from-kitchen-tap/m-p/43961
Thanks,
Nina
Welcome to the Bunnings Workshop community @NinaSD. It's wonderful to have you join us, and many thanks for your question about removing a sink tap adaptor.
Which of the three sections are you having difficulty removing? I note that you installed the fittings by hand, but are you also trying to remove them by hand? If so, have you tried using a tool such as multigrip pliers?Please let me know if you have any questions.Mitchell
