Hi All,
Recently moved back in and the previous tenant's dog has ripped up our beautiful SWB.I was in the middle of fixing it but realized that there are rocks and clay soil on the turf underlay (looks like the landscaper did a shortcut and did not clear it properly before installing new turf)Should I just order Sandy Loam to level the lawn and install new turf on the areas required? This is what it looked like when it was freshly installed before:Original Freshly Laid LawnOriginal Freshly Laid LawnBefore landscape at the backBefore landscape at the backBefore landscape at the backBefore landscape at the backCurrent SituationCurrent SituationCurrent SituationCurrent Situation
Hi @toffeeapple
That is another possible method to repair your lawn. It would be a more cost-effective method to install a drain rather than dig up the entire lawn just to level the soil. I suggest having a look at using Everhard 1m EasyDRAIN Polymer Grate And Channel, they can be joined together and cut to length.
I also recommend using Vinidex 100mm x 20m Socked Slotted Draincoil to help drain and carry the excess water away. It might take a longer period of time, but if you are willing to put the effort in, you should be able to restore your lawn.
I've just received a quote of around $7k to dig 20cm deep and level the lawn (as I was planning to put 150-170mm of sandy loam and 30mm of turf).
I was thinking, would it be more efficient to have a plumber install a drain near the patio as the yard slopes slightly towards the house? That way we don't have to dig the entire lawn? I can just put around 30-50mm of sandy loam and returf the areas needed and top dress the remaining grass.Overtime I can fix the clay soil via fertilizer/compost etc?
Hello @toffeeapple
Thanks for sharing your question about starting over with a new lawn.
Although you still have patches of green, I'm unsure if it will be enough to recover the entire lawn. But if you are starting from scratch, your idea of covering the surface with loam soil is an excellent idea. This would also be the best opportunity to re-level the surface of the soil before you lay down the turf. I suggest using a builder's line so that you'll have a guide when spreading the soil.
Also, I'd like to add that I'm stuck on the following:1. Rocks and Clay on soil
2. Looks like the lawn slopes down towards the house. Lawn was flush with the concrete slab where the aircon unit is (happens to be lower point than the garden bed, maybe I can build a wall around the concrete slab?)
I thought about shaving some land where the garden bed is but that will compromise the wall stumps so may not be an option.
