I am unsure if the green has transferred from the soap bottle, which was placed on it, the silver is stained green. How can I remove this without damaging/scratching the silver off?
Hi @joejoe,
Can you tell if that insert is stainless steel and metal, the same as the tub, or is it a plastic insert? You can use a scourer or try some stainless steel cleaner if it is metal. If the green buildup comes off easily, you likely won't need to scratch the stainless steel. If it's more stubborn, you might need to polish it back up again after the cleaning process.
If the insert is plastic, you must be more careful. Start with a soft bristle brush and some warm soapy water. Let us know if that doesn't resolve the issue, and we can try other methods.
Thanks Mitchell. It came away, unfortunately it looked/sounded like metal, but was plastic. Some of the silver came off. How can I repair this?
Also any advice on how to remove scratches in a stainless steel sink?
You might like to touch up the plastic insert with some chrome spray paint.
Fine scratches in stainless steel can be buffed out with polish. For deeper scratches, you'd need to work through various grades of sandpaper until the scratch is minimised before polishing. You might start with 600-grit and then work your way up to 1200-grit. Sink tubs typically have a brushed finish, so you might not need to go above the 600-grit for a reasonable result.
Thanks Mitchell, is it possible to have this post deleted?
Typically, posts on the community are not deleted as they provide a great deal of assistance for future members with similar issues.
I'll reach out via private message to discuss further.
