All right, here we go. Planning another project 😉
I am getting the asbestos containing internal wall and ceiling lining removed from two bedrooms and so I need to reline with Gyprock.
Haven’t never done this I have few newbie questions:
- I’ve seen few install videos and they always put an offcut under a sheet to form a gap between floor and sheet. How is this gap sealed? Or you are supposed to leave it and cover it with skirting boards?
- How do I work around existing window casings/sills and door frames?
- We have got exposed beams as seen in the attached photo. How does one plaster around those?
- Insulation - can I put battens into the wall cavity from the inside even though there is no vapour barrier between behind the cladding?
Any advise is much appreciated!
Thanks,
Tom
