Hi. I'm adding leaf eaters but want them to blend in with existing colorbond walls. Can I use Metal Shield spray paint on PVC? Thanks
https://www.bunnings.com.au/dulux-300g-metalshield-multipurpose-spray-paint-paperbark_p1400658
Hi @Steve5
The paint you want to spray on will work but can be chipped of fairly easy.
In the paint department the is a high grip undercoat that may give you a better surface to spray on too as I want to paint plastic down pipes.
Taken from Bunning website
Hi, Thanks for info, I wondered about roughing up the surfaces but this looks like it solves the issue.
hi @Steve5
A little bit of a rough up never hurts either with sand paper micro scratchs
good idea
I suggest having a look at this discussion - How to paint PVC downpipes? by @sachinriz. In the discussion I recommend sanding the surface with a 240grit sandpaper and washing it with sugar soap. Once the surface of the pipe is dry and prepared then you can put the primer on.
