hi guys
Looking at buying this second hand bed but it has a couple of broken slats. How easy are they to replace please? Thanks
Hi @DavidBrent,
The slats look to be around 70-90mm wide and 19mm thick. You should be able to easily remove the broken slats and replace them with similar-sized timber. Replacing the boards should be a straightforward process as they are typically just laid in position and no fixed at all; you'll just need to pick up the correct-sized replacement timber.
