I've bought 90mm radius hinges to replace existing old hinges during our home renovation. I also purchased the Ryobi Door Hinge Kit and Ryobi Trim Router from Bunnings for routing the mortices in the door. Problem: The Ryobi kit does not do 90mm hinges! It does 100mm, so I thought to mortice one end, then slide it back 10mm to mortice the other end. However, the Ryobi hinge kit template also provides too much space between edge of door and the hinge. To use it would be to leave an ugly 3 or 4 mm gap between edge of door and hinge. It also fails to help me mortice the door jam.
So my ultimate question: How do I do this? What tools do carpenters use to neatly mortice the 90mm radius hinges to both door and jam. I prefer not to do them manually with a chisel if possible.
Thanks for advice for a solution!
Regards,
Geoff
