Hi All,
I have just joined the community after reading several threads about filling in the gaps between paving bricks.
I have been battling with weeds in my yard and decided that I should try a more permanent fix. Hopefully I can get some insight and advice from the members here. Thanks in advance.
I am thinking of weeding once off and filling up the gaps between the bricks.
I have multiple questions to this quest
1. Regarding weeding - Would I need to weed by hand or can I just use a pressure washer to remove weed and soil/sand between the pavers? Problem is by the time I go through the yard, weeds would have started growing from where I started ! I do it only in the evening after my work, so I go through small portions at a time. But these weeds are ferocious! You can see in the photos areas which I recently weeded and areas which I had neglected over the past month or 2.
2. I am not too sure whether to use polymeric sand, sand or sand and cement. I am wondering which is most suitable for my purposes. I read that 1 bag of the Dingo Powerloc could fill 3.5m2. I would require around 6 to 7 bags for my small yard which amount to $140. Would sand or sand/cement be sufficient? Beneath the bricks is just dirt.
3. Would the Polymeric Sand be able to fill up the larger gaps. Some of the bricks are worn and the corners chipped. Could I just use the sand to fill this gap or do I need to something else to repair it?
Thanks,
Andrew
