Hi all, wondering which product is best for this repair? Could I use Poly 310g Large Interior And Exterior Cracks Filler or repair mortar?
Thanks,Daniel
Welcome to the Bunnings Workshop community @danielv. It's marvellous to have you join us, and many thanks for your question about filling a hole in concrete.I'd recommend scrubbing any debris from the hole with a wire brush. Once the hole is spotless, you can use Earl's 1kg Concremate Expanding Cement. Only fill the hole so it is flush with the surrounding surface, as this will minimise the amount of sanding required to get a smooth result.
You could use Dunlop 5kg Ardit Rapidset Repair Mortar, but I wouldn't suggest using the Polyfilla product.
Hi @danielv
My moneys on @MitchellMc rapid set mortor no expansion so set and forget usefull to spritz the concrte with water before adding mortor.
