Hi.
I need a rental friendly way too keep things from entering underneath a storeroom located outside which has no protection from rain, pets etc.
Hi @joejoe
Consider using a plastic stripe with a foam bead along on the outside it so when door closes the foam seals to the door.
or there are a bunch of commercial weather door strips at bunnings on offer EG
I/N: 4061472
$35.88
Hi @joejoe,
Typically, landlords will be quite open to having their property improved by a tenant at the tenant's expense. You might like to explain that you see water and insects entering under the door and request they allow you to install a simple self-adhesive door seal.
If you were to clean the concrete well, then a foam weather strip could potentially be adhered to it. However, I'm not sure of what the longevity would be like as, typically, the adhesive doesn't adhere well to concrete.
