Do ready made adapter allowing you to plug a 10amp cord into a 15amp socket exist? I do know in most cases a 10amp plug will work fine in a 15 amp socket but my double 15amp outlet is safety shuttered and the smaller earth pin on a 10 amp plug does not always open the shutter on the 15amp earth socket pin without some wobbling it about and therefore I suspect/worry that when I do, the earth contact is probably not as good as it could or should be. I don't want to swap the leads on the 10amp devices to a 15amp ones as that would prevent their normal use on a 10 amp outlet. I could I guess make an adapter myself by attaching a 15amp plug to a 10amp extension lead or just making a very short lead with a 10amp socket at one end and a 15 amp plug at the other end but I would have thought there might be more elegant ready made solution around.
Perhaps it's something to do with the issue discussed here https://trailersailerplace.com.au/phpBB3/viewtopic.php?t=5800 i.e.
" .... suggests that newer 15 amp outlets (especially commercial ones) have a restrictor built in that stops 10 amp plugs being put into them direct, even though they would otherwise fit. This is to stop people using dodgy cords that they had made that are 15 amp female (to connect to van or boat) and 10 amp plug to plug in at home dodgy style. It appears that many were using these same dodgy cables at a proper 15 amp outlet so everything was 15 amp except for the plug - thereby potential for issues.
It appears that some new 15 amp outlets require the large earth pin of a 15 amp plug to release a cover that otherwise restricts the top diagonal slots."
