Hi, we're in the middle of a laundry Reno. We've pulled out the trough and mounted cupboards. We're putting in a bench, should I add some bracing around the side and back walls and put the bench on top of the bracing? We'll be attaching it to studs either way but the studs in our whole house are all over the place so I just wanted to make sure it was as secure as possible.
Based on the Bunnings staff members recommendation we got Cabot's cabothane clear satin CFP floor polyurethane to swap the benchtop (Tasmanian oak utility panel). Just checking this is the best option to seal and also going to help prevent damage/scratches. Should we put this on before we install the benchtop or after?
