Hi
I'm trying to Build a structure to hang the fence panel below, thinking of setting up a few posts, run some horizontal timbre between the posts then use screws to hang the screen on top of it. This is all in front of my colourbond fence. Is this the right way? Also I don't see enough space on the panel between the vertical lines to put through the screws.
https://www.bunnings.com.au/specrite-1800-x-902mm-pre-oiled-merbau-alternating-slat-fence-panel_p8500281
Thanks
Hi @AJ-DIYer,
You're correct that the space between the slats is a little small to place your fixing screws through there. Is there enough space behind your frame to install the screws from the rear? If not, you could fix the horizontal timbers to the back of the panel first. You'd then position the panel between your posts and screw through the sides of the posts into the ends of your horizontal timbers. That way, there are no screws exposed from the front. If you were to fix from the front, you'd likely have to do so through the slats and then disguise the fixing holes with Merbau timber putty.
Building a stand-alone structure to mount the panel is probably the best idea. However, we have had members fix directly onto the top and bottom rails of the Colorbond fence.
Hi @MitchellMc
What should be the distance between the posts?
Can I have 2 posts 1.8 metres (equal to the width of two panels) apart and have them connected with 3 horizontal timbre pieces to hang the panels on?
Thank you.
Hello @AJ-DIYer
The distance of 1.8m is actually one of the common distances used for fencing. I actually prefer the shorter distance of 1.8m as it limits the rails or horizontal timber pieces from bowing. The further apart the posts are the greater the likelihood of the rails bowing.
However, I always suggest putting your plan down on paper or your PC. Having a visual reference is always handier and eliminates guess work when you begin assembling your fence cover.
Thanks @EricL
What should be the size of the horizontal timbre pieces? Which type is best suited for this?
I'd use these 75x38mm Pine Fence Rails.
They are specifically designed and treated for this purpose.
Cheers,
Thanks, unfortunately the link is broken. Is it supposed to be another size like the following ?
70-x-45mm
Hmmm, that's odd. It may be because I'm in QLD and the supplier is different in your part of the country.
If you go to the Bunnings website and type in "fence rail", it will give you a number of options that you can use.
Note that they all state they are "H3 Treated", this means they are treated for external above ground use.
Hope this helps,
thank you!
Hi @AJ-DIYer
It's great that you've received excellent advice from @JacobZ95. Just to add to the suggestions made, I recommend visiting your local store and having a look to see what's in stock for fencing rails.
You can then organize it to be cut and delivered to your home. Please note that the cuts made are for transportation purposes only, it's best to do all your precision cuts at home. Please make sure not have any of the lengths undercut to your needs.
Hi @EricL, @MitchellMc
I'm planning to install the posts for the frame on top of Pyrda stirrups that bunnings sell.
My posts are 2.4m long. What should be the height of the stirrup to go into the ground?
Thanks.
I'd recommend using these Pryda 450x90mm M10 Full Stirrup Post Anchors and having the entire leg concreted in the ground with only the mounting section above your footer.
Thanks @MitchellMc
How many horizontal timbre pieces do I need to run between two posts that are 1.8 metres apart? do I need to 2 or 3 horizontal pieces? Since These timbre pieces have to be aligned to the pieces attached to the back of the panels.
If you went with 90 x 45mm, you'd likely be able to run one at the top and one at the bottom. I'd recommend joining the panels together on the remaining two middle pieces on the back of the panel with mending plates. That will help the 90 x 45mm timber to not sag.
Can you help me understand how to use the mending plates to join the panels together on the remaining middle pieces?
Sorry for the slow reply @AJ-DIYer. Unfortunately Mitch has had to take some unexpected leave.
Let me tag @EricL to assist as soon as possible. Thanks for your patience in the meantime.
My apologies for the late reply. The mending plates are placed between where the two panel joins to serve as a supporting element for the panels. I've sketched up an image below to give you an idea of where the plates are to be installed.
The plates are usually installed at the back where it can't be seen.
