We’ve bought a new fridge which “suggests” in its manual to have 50mm clearance on all sides to assist the hot air to dissipate.
We only have 22mm on all sides, 40mm at the top. The cavity it is going in also has a void above it that’s about 850H x 850W. As I am unsure whether this will still be a heat trap, I’m thinking about putting an air vent (link below) into the ceiling space.
https://www.bunnings.com.au/haron-285-x-225mm-white-ceiling-vent-with-baffle_p0814396
Will this help the hot air escape or does the vent need to vent out into the outside? Or am I going overkill and the existing 22mm clearance and cavity will suffice?
Appreciate any thoughts and suggestions.
