Hi.
I'm ready to form up my bath and shower surround,
Walls:
https://www.bunnings.com.au/james-hardie-2400-x-1200-x-6mm-2-88m-villaboard-lining-2400-x-1200-x-6_p0714174
Floor:
https://www.bunnings.com.au/james-hardie-1800-x-1200-x-6mm-2-16m-ceramic-tile-underlay-flooring_p0716142
For waterproofing, I've usually used:
Membrane: https://www.bunnings.com.au/bastion-4l-under-tile-membrane_p0363840
For the tape I usually use a mesh, however I see Butyl tape is also used. As I will be tiling, wouldn't the mesh bet better? Thinner profile?
That look right?
Hello @Kurt1
Using a mesh is the preferred method when water proofing. However, before you begin, I suggest checking your local council's rules and regulations regarding water proofing. It might require you to engage the services of a certified trades person to apply the waterproofing as they will need to sign off on it.
In regards to your choice of wall and floor liner they should work nicely.
