I'm looking to install a doorway to separate one bedroom area from the rest of the house's living areas and other bedrooms for privacy and sound insulation (older people at this end) but unfortunately I have the air con return duct located in the bedroom area side of the hallway (i.e. on the other side of the proposed new internal door). I still want to be able to run the air con after closing the door, but need the air to flow to the return duct. (see markup below).
I THINK I'll be able to do this by installing the door as pictured, but somehow installing a "bulkhead" type structure to allow air to flow above the door to the return duct in the ceiling.
The issue is, the house is a steel frame house. I don't want to cause too much damage as when it comes to sell, it might need to be returned to original layout. How best to do this? I was thinking just some 2x4 framing to support some drywall lowered "ceilings"....(maybe with insulation of some kind to still provide noise insulation). The size of the oroginal return duct is 55 x 75 cm for a total area of 0.4125 sqm. If the "gap" above the proposed door is 45cm, the width of the new return duct would need to be .4125/0.45 = 0.91 m (or 91 cm), which is fine as the current width of the hallway is 100cm. I would install a return duct of say 45 * 95 or something above the door to allow the same volume of air to flow to the original duct).
Is this:
1. Is this feasible/Possible (will I be doing damage to the air-con unit at all - even though the flow will be able to be maintained?)
2. How best to support the new lowered ceiling height by tying into existing vertical steel frames through the existing drywall/gyprock?
Thanks in advance.
