what’s the best way to deal with these electrical power outlets? I want to render behind the box. Is it get an electrician to remove and then I render then get them back to reinstall? Or can they come away a bit whilst I apply render behind?
Hi @JamesG,
It's likely best to have an electrician remove the outlet, allowing you to render behind it. They'll then need to re-install it after you have finished. They might be able to disconnect it from the wall temporarily. Still, I would advise leaving that to the professionals instead of risking doing the work yourself and trying to loosen it.
