hi, I’m just wondering what I can use to connect the pipe to the sink, is there some sort of flexible tubing I can use? Or do I need to redo it altogether?
thanks
Hello @ben1984
I'm afraid the long extension elbow has been cut too short. Technically the two inlets must be in line with the waste outlets. I recommend using the Caroma 50mm Double Bowl Connector to replace the set that's currently in place. I suggest attaching the inlets to the outlets and lining up the joins and marking the PVC where it needs to be cut.
Since the bowls are uneven, I suggest using Art Plastics 50 x 45mm DWV PVC Extension to line up the waste outlets. Please remember to sit the O rings properly before joining any of the pieces together.
Please note that it might be necessary to engage a licensed plumber to complete this work. If in doubt consult your local building authority before you begin.
