Our blinds have recently stopped working - when I pull the draw string it only rotates on one direction and doesn’t go the other way.
Is there something broken in the mechanism I can replace? How do I get it off the window frame?
Hi @androidhaig,
The internal mechanism is likely broken, but given parts are likely not available, it might be worth considering replacing the blind. There are some budget-friendly options to choose from.
The blind is attached via those two square fittings on either end. You might find screws or catches that retain the blind in them. There is not one universal method of removing these types of blinds, so you'll need to take a close look at those end brackets to determine how they release the blinds. I can't quite see in your image, but there looks to be a little gate latch on the front that runs from the top of the bracket to the bottom and is clipped over the bottom edge. Try popping that latch off the bottom edge of the bracket.
Once you remove the blind and if it has an open top, you should be able to check to see if a part is broken or whether there is some type of jamb in the mechanism.
