Hi there,
I am planning on revamping an existing bathroom by painting over tiles and the original laminate cupboard and benchtop.
From what I researched I can use White Night primer & paint from both tiles and cupboards and even the benchtop,
My question is that, I want to protect the benchtop with an epoxy top coat? I know that Bunnings has a product "Protite Glass Coat Kit" can this product be used on painted laminate? The features on the information sheet does not mention laminated coated timber and the in the video he is using timber?
I was thinking that my process for the benchtop should be as follows:
- obviously prep, sand & clean the surface
- then apply the White Night tile & laminte primer
- then apply the White Night tile & laminate paint
- then apply the Protite Glass Coat
Also, how can I use the Protite Glass Coat on the 30cm edges of the benchtop along with towel rails? And do I need to remove the basin?
I have attached a photo so you can better understand the project.
Any help or suggetions you can provide would extremely helpful or am I being too ambitious? 😬
